CRRC GP26R Break in
CRRC GP26R Break in
The instruction manual for this engine states to use mineral oil for break in.It also states that the engine break in time is 20hrs. Should
I run the Engine on mineral oil for the full 20 hrs?
IL
I don't know what everyone does but I breakin on the oil and the prop that I will always use.
There is a write up in here on a much recommended by me and the guy who discovered and came up with a fix to a carb pump problem. The carb pulse hole ends in the reed cage. This causes the pulse hole in the carb to see only negative pressure pulses. The fix is to modify the carb and crankcase for a line from the crankcase to the carb pump pressure pulse side.
