RPM change on landing
I have been to many fly-ins & I notice some guys can do about any trick you can think of in the air, but blow the whole show on a crummy landing. So when I see a guy like "Jase the Ace" fly & land perfect, I really enjoy that. He is from West Michigan....
https://www.youtube.com/watch?v=9RAatLQi8m0
WI
Mix in a lower throttle idle setting (Idle throttle position) with a switch on the Xmitter, when you land flip the switch your idle will be lower. Don't forget to put the switch back to "normal" mode for the next flight or your idle will be too low.
