DLE 20Rear exhaust clear mount
My Feedback: (9)
Can't tell in the pictures, are the two exhaust tips on the new rear exhaust DLE20 narrower than the beam mounts? I am going to convert a glow plane to gas that uses a stock glass beam mount and want to be sure it fits.
http://www3.towerhobbies.com/cgi-bin...&I=LXDWDW&P=ML
David
David
My Feedback: (19)
I'm not sure I understand this question. The muffler outlets are usually well away from any motor mount beams just like the photo you linked to. From there I would assume the muffler outlets are wider than the beam spacing if that is an issue for whatever reason. Carb clearance is usually more of an issue when converting from glo to a rear intake gas engine.
