Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
Motor Mount That Fits a DLE 20RA Engine
Old 01-05-2015, 05:09 PM
bfair67
Default Motor Mount That Fits a DLE 20RA Engine
Any recommendations for a motor mount that is suited for a DLE 20RA Engine. I tried a DU-BRO No. 688 but the beams are to short. The muffler hits the mounting bolts in the rear. Help!
Old 01-05-2015, 05:45 PM
Truckracer
My Feedback: (19)
The Hanger 9 HAN2033 aluminum mount works. There are also several plastic mounts that work.
http://www.horizonhobby.com/product/...-61-22-han2033
Old 01-06-2015, 02:55 AM
Lifer
Lifer's Avatar
Plus 1 for the HH aluminum mounts. They are a perfect match for the DLE 20.
Old 01-08-2015, 02:57 PM
Redtail_Customs
Wish I would of read this earlier I ordered the Dubro mount and the the one from horizon .
I
i emailed one shop and the responce was im doing it backwards she said you usually get the mount first them buy the engine .
jim
Old 01-13-2015, 03:48 AM
bfair67
Thanks all for the help, I went with the Horizon Mount. Hobbico the DLE dist. was NO HELP AT ALL! MUST BE RELATED TO HOBBY KING!
Old 01-15-2015, 03:16 PM
roscoerc
wish the DLE 20RA manual wouldn't list the dubro mount as acceptable. I got the engine and mount from Tower last month. needless to say, it doesn't fit. I ended up getting some 1/2 " aluminum square stock from work and made spacers to fit between the engine lugs and the mount beams. I used 5 #8 cap screws per side to bolt it all together from the engine, to the spacer, to the beam. it works, but it was a pain.
Old 01-15-2015, 07:31 PM
Checklst
My Vallyview 21cc took a mount 4" long engine mount, from firewall to end of mount............anything shorter might not work, gas engine with rear carbs and carb blocks due get a little long. My engine is just far enough off fire wall to allow the choke plate to operate.
Old 01-20-2015, 03:46 AM
bfair67
Thanks for the info roscoerc. I used the mounts that came with my Horizon Super cub, that I didn't use on it, was a good fit and made of Aluminum. How do you like when you talk to a hobbico Tech. they tell you you must of mounted the mounts backwards. Get him a job at Hobby King! Thanks again for the info.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
