Sachs 4.2 engine
Old 08-17-2015 | 08:12 AM
Default Sachs 4.2 engine
NEED HELP PLEASE; I have a 4.2 sachs converted to cdi, has shielded harness, spectrum 8 2.4 radio, receiver 13 inches from cdi unit. Current plug is a champion DJ7J. Engine starts and runs great, however when the engine is running I am getting severe glitchs on the ailerons. I have been told that problem may be the plug is not a resistor type plug. I cannot find any info as to what plug should be used in this engine, does anyone know, name and number of plug.
Joe
Old 08-17-2015 | 10:28 AM
You were told right about the none resistor plug.
You need a NGK BPMR6F spark plug, The R in the plug type stands for resistor plug.
Milton
Old 08-19-2015 | 07:59 AM
You can also use the Champion RCJ8 plug,if u cant find the NGK,
Old 08-19-2015 | 11:55 AM
And, make sure the plug cap fits securely. Good luck
