Brison 52 bearings
My Feedback: (23)
FL
Brison 52 bearings
Prop hub rotates without hangups, but you do feel a little resistance. How free should it be.
To get the crank out does the hub with key have to come off first, and how do you get it off.
There is a Woodruff key holding the propeller hub to the crankshaft. It may take a long bearing puller to get it off if heat was used putting it on. Yes it should be removed to get the crankshaft out of the case. The shaft is the only thing holding it in position. Since you are asking questions like that, I would advise you to get in touch with Scott at the following website to get it done right.
aeroscott.com
aeroscott.com
