Six bolt hubs
AZ
Six bolt hubs
I hate six bolt hubs. I just spent the better part of two days fitting a prop on one. I have a drill guide and a drill press and something always goes wrong. I am not a machinist. My G62 has a single bolt hub, why does a 44cc twin need six bolts?
OR, buy a single bolt adapter. Good luck.
Sincerely, Richard
[h=5]DL 30 Single Bolt Stud 10mm Thread[/h]Availability: In stock
View $29.95
Add to cart
[h=5]DL 50/55 Single Bolt Stud 3/8-24...[/h]Availability: Order Now
View $29.95
Add to cart
[h=5]DL 50/55 Single Bolt Stud 10mm...[/h]Availability: In stock
View $29.95
[h=5][/h]
[h=5]Single Bolt Stud 3/8-24 Thread[/h]Availability: Order Now
View $25.00
Add to cart
[h=5]Single Bolt Stud 3/8-24 Thread[/h]Availability: In stock
View $25.00
Add to cart
AZ
I did that but with the plastic props I happened to have the back side of the prop has been relieved. So if you happen to drill a hole next to one of the webs you have to go in with the Dremmel and grind out the drill path. All that takes time.
On a wood prop that works OK
But then you still have to put in six bolts every time you want to change props.
Use a very high drill speed, and go slowly as you drill. It should chew right through those webs that way. And as mentioned, put a bolt the same size as the hole in each time, and tighten it with a nut to maintain alignment. To answer your question, adapting it to a single prop nut is entirely acceptable.
AV8TOR
AV8TOR
My Feedback: (29)
AZ
Its a Master Airscrew Classic. I guess I should throw it away and get a wood prop.
The center stud is 10MM. I have a stepped ream that I got from Boeing surplus that does a very good job of reaming the center hole.
Too bad I didn't get a set of Boeings high speed drills.I will have to go to Home Depot and see what I can find.
I still hate six bolt hubs.
