Da 50 slow to idle down
My da 50 is idleing up fine,sounds good but is very slow to idle down,what would cause this?some type of carb problem,definently not the servo,thanks for any help
My Feedback: (19)
Probably just needs a good carb cleaning and new diaphragms. Reset the needles making sure it is not too lean on the low end. Being too lean on the bottom end can cause the engine to "hang" on a high idle for a bit before it settles down to a normal speed.
One thing to watch for on the DA50 is the white colored reed cage the carb seats against. This part is prone to warp over time (especially if the carb bolts are over tightened) causing an air leak. if you can see excessive distortion, I'd recommend you replace this part along with new gaskets in the area.
