low top RPM DA50
low top RPM DA50
Hello I have a new Da50 engine that I am running and has nearly no use. I have tuned it but the problem is that my RPM wont pass 6000 no matter what propeller I use in the engine range. The iddle is fine and the transition is good too but the top RPM seems too low. I have used the following propellers with the same results +/- 200 rpm.
2 blade: 22x8 menz 22x8 mejzlik
3 blade 20x10 biela and 20x10 mejzlik
I have checked the ignition abttery is fully charged and the throttle servo has full travel.
Any ideas?
Any ideas?
