throttlle arm orentation
MI
I bought a P 51 with a Mintor 22 on it,I believe the engine is New?? not sure.
The engine is on the plane and I haveit all wired up to fly/run. But I can't tell if the throttle arm isat idle or high end?
Plus the choke has its own servo and Ican't tell which is on or off.
Can anyone tell me which way is idleand chokes off? I don't really want to take the engine off to find out.
sticks
sticks
Choke is open when the choke arm is leaning toward the front of the engine. I believe this is a "push" open, "pull" closed. For the throttle, I would disconnect the arm at the servo. Throttle should automatically go to closed. You can then manually pull/push on the control rod to see what direction it will move. That will be the "full throttle" direction.
MI
I went and checked, there is no spring on the thr. arm. but I figured it out. on the bottom is a idle set screw for the low end. there is not screw in it but that tells me the thr. is closed when back away from the prop.
Still not sure about the choke , but that should be evident when trying to start it.
you got me looking at it and we got it.
thanks for the reply, if anyone know about the choke please let me know.
sticks
sticks
MI
now for some fun getting it out doors and firing it up, I have some 30:1 fuel ready to go.
I can not see the plate, there is too much around it.
I have Zenoah 20 also, just got the elect mod. for that. I also did not get paper work with that engine. will have to ask about it also.
thanks for the help
sticks
sticks
MI
hi there stik , nothing you do to the engine is going to be worse than its own out of round cylinder , lack of parts ,no customer service ( i think there not in business anymore but they had none when they were ) . Just use it until it blows up and use the carb ignition and chuck the rest . When u see the guy who sold it to you , kick him in the nuts . He probably didnt run it because he knew what was going to happen . Check out the flying giants thread and all will become clear . Remember your not alone I have 2 . I just spread the word when i can so others hopefully wont get burnt , Cheers
MI
I am just about ready to run it, went back and read the "sticky" on "newbies to gas " at the header of the forum. got a lot of good info and have to change some things as he did not set it up right.
I will get back if I ever get to running it.
The balsa USA stick 40 was my trainer plane, back in the day.
thanks
sticks
