DLE170 question
Old 04-25-2016 | 01:02 PM
My Feedback: (10)
Default DLE170 question
I have two DLE 170's in two 40% planes. They both have the same issue of running rich on low end. When I adjust either one of them to where they have a smooth low end they are so lean they wont start. When I richen them up a bit they start but have that annoying burble I cant stand. The first one I change the carb, ignition, the battery, set the timing to both ends of the slotted spectrum that you are able to adjust but still have that burble. Any thoughts.
Old 04-27-2016 | 08:38 AM
speedracerntrixie's Avatar
My Feedback: (29)
A few things to try, gap the plugs to .024, very small adjustments on the low needle. Lean until it takes a short warm up to transition. Try a prop with more load.
drastic fixes. Replace the carb with one just slightly smaller. If the airplane can accomidate, run a canister exhaust system.
