Ignition module hook-up
Old 04-12-2017 | 09:36 AM
Default Ignition module hook-up
I am new to the electronic ignition field, and have a question. In the small airplane I have put my 15cc engine into, I cannot arrange the module so that both the high-tension lead and the timing lead will reach the engine. Can I just make up an extension for the timing lead? Or will that interfere with the signal?
Thanks for any help.
Jim Brock
Old 04-12-2017 | 10:30 AM
kmeyers's Avatar
If nobody responds who has done this, you could test it out and let us all know your results.
Old 04-12-2017 | 11:25 AM
My Feedback: (48)
I haven't done it, but I don't see where it would be a problem.
Old 04-12-2017 | 11:39 AM
All Day Dan's Avatar
I solder in an extension to the pick up lead all the time with no problems at all. It does not effect performance . Dan.
Old 04-12-2017 | 04:46 PM
Thanks, all. I will proceed to the test stage!
JimB
Old 04-12-2017 | 06:21 PM
My Feedback: (19)
I have used a short extension on one installation with no problems.
