ZDZ 80b2 inline help
Old 04-18-2017 | 07:53 PM
Default ZDZ 80b2 inline help
I have a brand new zdz 80 inline engine with the bing carbs, the falcon ignition, and 14mm plugs. I set the engine needle valves both H and L at 1.5 turns. This engine has 2 pick ups, one on each side of the prop hub. I made sure the active ignition is connected to the cylinder with piston at TDC.
When I tried to start it, it pops 3 times but didn't run. The funny thing was I tried to swap the ignition around, the engine cough the same way and still didn't run. When I tried this I didn't even expect it to pop at all. But it did.
Anyway, if you have experience with the inline engine, please help.
