Coleman Fuel in Gas engines?
Yes some do .
I have found Avgas 100LL to work well for me in both small and large gassers. It doesn't dry up the carb diaphragms and lines like pump gas does. Some say it leaves heavier deposits on the plugs but I have a 10cc with over 14 gallons of fuel through it and the original plug failed at around 13 gallons.
The currently available Coleman camp fuel is not actually gasoline like it once was long ago. It is now comprised of mostly or wholly heavy naphtha aka mineral spirits, lighter fluid, etc. It has a low octane rating, so using it in higher compressed engines may cause knocking. It doesn't have the energy content that gasoline does either, so power will be reduced some and ignition timing may need to be adjusted. Add to that the cost is highly prohibitive as well. if one insists on using that type of fuel, you could save yourself some money and get a jug of "odorless" mineral spirits from a home improvement store. If it smells like zippo lighter fluid, it's the right stuff.
Running a G38 on a 18X8 prop on white gas (Coleman Camp Fuel) at 32 to 1 Amsoil Saber Professional Synthetic oil.
Dennis
I have a close friend whos wife is reactive to gas vapors . He used Coleman fuel to get away from the vapor issue .
He constantly had overheating issues in all the planes and helicopters.
He kept breaking crankshafts and burning pistons until he finally gave into my advise to use avgas .
Since using avgas he has had no more overheating issues , no more broken engines of any kind and the engines start easier and stay in tune .
My advice is Don't Use Coleman fuel for your planes and helicopters.
White gas (the REAL stuff) would work fine. But it hasn't been made for decades. It was replaced with a less flammable alternative - naphtha - as I mentioned before. Unless your Coleman camp fuel is 30+ years old, it's NOT gasoline and shouldn't be used. If you don't like gas fumes, put a Walbro 499 carb on your engine and run it on methanol. Methanol is far cheaper than Coleman fuel.
I don't think you will find an engine manufacturer anywhere in the world that recommends less than 87 octane fuel. Coleman Camp Fuel has an octane of around 50.
I have used Coleman Fuel as an after run/storage fuel. Even with a just a short, quick ground run, my engines ran much hotter.
As I said, you will find people using it, but I certainly don't recommend it. Whatever your issue with standard gasoline, the only safe and viable alternatives are to search out alcohol free standard gasoline, use 100LL avgas, or convert to methanol.
As an aside, I found while using Coleman Fuel strictly as an after run /storage fuel to keep my carb and fuel systems wet but alcohol free, that after about two months time, the Coleman Fuel that had been mixed with oil would not run an engine at all, or sometimes would run, but severely misfire.
AV8TOR
AV8TOR
Use Ethanol free 91 octane instead. Naptha is an additive used to reduce octane at certain times of the year, along with Benzine. The only time I smell gas is when I forget to plug the vent line, or spill some.
