Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Need I.E. Module for a Fuji 50 or....? >
Old 10-17-2017 | 12:41 PM
My Feedback: (14)
Default Need I.E. Module for a Fuji 50 or....?
I have a 50 CC Fuji Elect Ignition but do not have the actual Fuji ignition module and spark plug connector/cap....... Could I use any IE Module and adapt it to the Fuji Connector that comes from the pickup at the prop plate area...? (I can not remember what that pick up part is called?) The Fuji connection has an unusual 3 wire connector... My DLE's have a standard 3 wire connector... I appreciate any and all recommendations ....
Old 10-17-2017 | 02:11 PM
All Day Dan's Avatar
Try here. Dan.
https://www.ch-ignitions.com/
Old 10-17-2017 | 04:56 PM
No, The original sensor is set to fire at about 18 degrees before top dead center.
http://www.rcextremepower.net/FujiIgnitions.html
Old 10-18-2017 | 04:00 PM
My Feedback: (14)
Default Thanks
I appreciate the replies.... thanks...
