DLE 35 Ignition
Old 11-04-2020 | 05:21 AM
My Feedback: (23)
Default DLE 35 Ignition
Will a DLE 35 ignition work on a DLE 30?
Old 11-04-2020 | 05:49 AM
BarracudaHockey's Avatar
I'm 90 percent sure they only make a single ignition and a dual ignition. So the single ignition for the 30 and 35 should be the same.
If you want to know for sure give Valley View RC a call, they will know for certain
Old 11-06-2020 | 09:13 AM
daveopam's Avatar
My Feedback: (9)
I've been told they are the same. No idea why some of the DLE ign boxes are stamped for "20cc only".
David
Old 11-10-2020 | 04:22 AM
The difference between the 30 and 35 is probably about the difference in the spark plug boots (90 degree on the 30 vs. 45 degree on the 35). I'm with David on the module itself. I see no reason why the single cylinder modules wouldn't be the same. -Al
