Will Nearby Magnets Affect Electronic Ignitions?
Hi All.
I want to house the EI for my DLE 35RA underneath the belly pan and have the pan attached using small round rare earth magnets as latches.
How near to the EI module can they be and still not adversely affect it?
(btw, this is just a mock-up. I realize the EI will need to be firmly attached, with foam padding and that the wires will need to be routed in a manner that does not allow for chafing.)
GT
GT
I can't answer your question about the distance away from the receiver but do a google search for an optical kill switch. There is one made that will cut out any ignition interference to the receiver. The big plus is you plug this thing into your receiver and you don't need an extra battery to power the ignition.
Carl
Carl
Carl
Carl
I do have an optical kill switch, it's just not shown in the photo. None of the electronics are installed yet, as I'm still in the building phase.
thanks for taking time to reply.
GT
Thanks, Truckracer.
I guess since a bunch of guys didn't jump in telling me I would destroy my ignition, or that the magnets would cause my engine to quit, it must not be a problem.
I'll proceed with installing them.
I agree with Truckracer, I don't think the magnets will bother the ignition box.
But, what I don't like about your setup is the very sharp bend the spark plug wire is being forced into right where it's coming out of the box.
Oh I like that WAY better! Nice job!
I think you did yourself a huge favor getting rid of that sharp bend. It's not like the electrons have problems with 90 degree bends, but the wire's insulation between the center conductor and the outer braid very well might have.
