RCS 140? Anyone with experience
FL
It is a great little engine. I have one in a H9 Edge at 12-1/2 lbs. plenty of power for most things but will not do full 3D stuff. If you can keep the weight down you will be surprised at the power of this engine. Mine turns an APC (wide) 17X8 prop @ 8400rpm.
My Feedback: (14)
MO
The RCS140 is a nice engine for 10 lbs. and under planes. Mine is on an 11 lbs. plane and vertical is certainly not unlimited. The idle is great but there is a large RPM step about mid throttle that could be a problem for aerobatics requiring throttle management.
I would say the power output to be in the area of the older vintage 120 glow engines. It is not on par with the newer YS, OS, Saito 120's.
I run a 16-10 APC prop on it. Don't know the RPMs with this prop.
You might also look at the MVVS 1.6 gasser. I have seen good reports on it. It is a little heavier, but it is also a larger displacement engine.
My Feedback: (14)
MO
jemo wrote:
"I don't have any trouble with throttle management with my 140"
Did you swap carbs? If so, what carb did you use?
I have had two of these engines and both exhibited large RPM gain when the disk transitions past the high speed orifice.
My Feedback: (14)
MO
snotlocker wrote:
"EXPO IS A WONDERFUL THING"
Expo won't get it, snot. I have a JR 10SXII and can manipulate the curve somewhat, but I would need a 10X with multipoint mixing (eight points) to get the bump programmed out :disappoin
Don't get me wrong, I really like the engine. This little quirk and some mixture weepage around the head is all that keeps this from being a great engine.
The first engine weeped severly and Mike Dooley replaced it with the one I have now. The new one weeped also and Mike suggested some HondaBond to seal it. That helped, but it still weeps some.
My Feedback: (14)
MO
Originally posted by snotlocker
i take it weeping is the same as a little leak ? at the head ?
if so mine dose this also ....ill try hondabond
Six flights today after HondaBond cured and the leak seems to have stopped.
Engine is coming on pretty good now after ~2.5 hours running. Need to go to higher pitch prop. 16-8 is not enough now.
