Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Mounting a spinner to the G-62 engine? >
Old 11-09-2003 | 06:43 PM
My Feedback: (32)
Default Mounting a spinner to the G-62 engine?
Hi All,
I'm at the point where I need to mount a spinner to my first gas engine, a G-62. This engine has a prop bolt, and not a threaded crankshaft and prop nut commonly found on smaller glow engines, so I'm wondering how to mount the spinner? The G-62 prop bolt appears to have a threaded hole in the end, so do I use a piece of threaded rod in this hole to mount the spinner adapter?? Does anyone know the diameter and pitch of the threads of the hole in the prop bolt?
John
Old 11-09-2003 | 07:43 PM
rctom's Avatar
Default RE: Mounting a spinner to the G-62 engine?
It's threaded for a 8-32 bolt I think. Just go to the harware store and get the longest 8-32 screw you can find. Cut to length. It must engage the threaded hole by at least 3-4 turns, the more the better.
TF
