G45 and B&B Muffler question
Old 12-28-2003 | 07:45 PM
My Feedback: (33)
Default G45 and B&B Muffler question
OK, so I have the Zenoah G45 and am replacing the stock muffler with a B&B muffler. The original muffler bolts have a square head and are way too long for the B&B. I would just cut the square bolts down to size, but they are not threaded the full length of the bolt. Does anyone have a remedy to this problem or know where I can get the correct length square bolt?
-Zip
Old 12-28-2003 | 07:57 PM
My Feedback: (16)
Default RE: G45 and B&B Muffler question
When I used my G45, I replaced the bolts and I had to grind the nuts so that they fit in the socket in the head.
Old 12-28-2003 | 09:05 PM
Antique's Avatar
The stock bolts can be cut off and be rethreaded, or you can get some 10-24 bolts and square nuts that will fit in the cylinder...Use lock washers and/or Loctite....
Old 12-28-2003 | 09:54 PM
My Feedback: (33)
Thanks for the input. I think I'll just go ahead and rethread them and cut to the length I need.
Old 12-29-2003 | 08:09 AM
My Feedback: (16)
I never thought about using square nuts!
Good information to have.
ORIGINAL: RCIGN1
