DA50 and slimline muff. mount
My Feedback: (23)
Using the slimeline wrap-around muffler, on one end there is a hole to use the muffler support piece. After trying several geometries I don't see any that work very well for getting the support piece attached to the engine from the muffler.
Would you guys tell me what you did and if possible, show a PIC, that would be even better.
The support attaches to the closest head bolt on that side of the motor( which would be L side, aft!). get the bracket lined up and the bolts started, then tighten the exhaust bolts and then the head bolt and last the retaining bolt on the muffler.
My Feedback: (18)
I installed it without the bracket. Blue locktited the bolts and used high temp permatex as a gasket. Seems to be working fine. The plate goes on the out side of the muffler where the bolts go through to spread the force of the bolts evenly.
HTH
Joe
HTH
Joe
