G-62 CHOKE PROBLEM
Old 02-17-2004 | 05:16 PM
2fast4u's Avatar
Default G-62 CHOKE PROBLEM
I could not reach the choke because it was on the back of the carb. I removed the plate and shaft, turned the shaft 180 degrees, ground a spot for the spring ball to hold, reinstalled, and checked the movement. I missed by about 15 degrees of being dead on.
My question.... Where can I buy this part. (Shaft and plate) I would like to do it again. Or is there a choke already made backwards that I can buy?? Feel free to PM me or just post here. If someone has an old carb to rob, that would be great too.
Old 02-17-2004 | 06:01 PM
Default RE: G-62 CHOKE PROBLEM
Horizon Hobbies will have the part you need.( www.horizonhobbies.com)......
Old 02-17-2004 | 06:03 PM
Sorry; I meant www.horizonhobby.com.............
Old 02-17-2004 | 06:24 PM
My Feedback: (15)
you could also try Ralph at rcignitions.com he may be able to help....
Old 02-17-2004 | 06:28 PM
Antique's Avatar
Try it where it is, 15 degrees will likely not make any difference..You might have to re set the high speed needle...
Old 02-17-2004 | 08:06 PM
2fast4u's Avatar
Thanks. This is why I love RCU. I plan to run it like it is till I can replace it. I just like things to be right!!!![8D]
