Magneto automatic timing module
Old 06-15-2002 | 10:38 AM
Default Magneto automatic timing module
Hey guys, Just wondering if anyone has played around with the fuji engines with the automatic timing module? I am in the process of converting an echo 34cc chainsaw it has the same ign I am wondering if I will have to flip it as fast? These engines are a little on the expensive side but easy to convert I have a 30cc on the stand right now very smooth power the 30cc is the same physical size as the 34cc but without the auto ign these are reed valve engines my 30cc with hangar 9 mounts and stock muffler weighs the same as a G23, very light! If you don't use the H9 mounts your 4 oz under the G23. You can mount the engine Right to the side walls of the fuse. Sorry I started to babble how does the auto ign work anyway? Thanks for your time! say, if you want to see an exploded view of the echo engines go to the echo home page then to technical documents punch in cs-340 or any of the saws or trimmers for that matter and enjoy the info! See ya!
POWER
Old 06-15-2002 | 12:01 PM
My Feedback: (16)
Write Ann Marie Cross. She may be able to help you.
She is a Senior Manager at Great Planes
