Brison ignition
I dont know about "always " But.......
I have only seen C&H on Brison Engines and some were fairly old (6 or 7 years)
All of mine were ordered from Brison as new and I was not aware of any other Ignition systems that they offered at the time .
WY
NOPE, before they learned the hard way
They had a Brison ignition.
It is an a black plastic case with a screw on aluminum lid
The current CH unit is a direct replacement for the old Brison ignition.
They had a Brison ignition.It is an a black plastic case with a screw on aluminum lid
WY
Brison makes good engines, but not so good ignitions. They spent to much time servicing/warrantying them.
Much easier to let CH worry about service and warranty
If it works then use it, when it quits then get a new CH ignition. [8D]
