3w 50cc
Old 03-18-2004 | 03:27 PM
Default 3w 50cc
hello
i am thinking of puting this engine on that plane.
has anyone tried that combo?
what prop should i use?
can i use a 4.8v batery for the ignition?
i would like to hear your opinion
thank you
roy
Old 03-19-2004 | 04:35 AM
Joe Hunt's Avatar
Default RE: 3w 50cc
What plane?
I have a video on my site of me flying a new one on a Wild Hare 84" EDGE540T. Still breaking it in... started out with a 22-8 wood prop and that started ripping at a little over a gallon of fuel... so now onto a 3W 22-10 wood prop.
Old 03-19-2004 | 06:55 AM
Default RE: 3w 50cc
sorry i forgot to write what plane: dave patrick edge.
thank you
Old 03-19-2004 | 09:16 AM
Joe Hunt's Avatar
Default RE: 3w 50cc
Having flown that plane I'd say a 2 lbs engine and ultra light gear would be the limit for good flying.
Old 03-19-2004 | 11:01 AM
rmh's Avatar
rmh
Default RE: 3w 50cc
DP Edge is a 15 lb setup -with any 50 -
skimp all you want - I really doubt you will hit 14 lbs--(get ready for the "not if you use a --- )
It really only needs a good 40 - but the 50 setup is a corker -
I have built and flown same plane ---both ways - It actually balances -stock - best with a light 40 gasser.
Only problem--it is an Edge - I simply don't care for them -any of em.
Personal taste.
that and the aileron servo setup is a PITA
All in all tho - a very nice. light strong model.
The 3W 50 is a bit porky - at over 4 lbs - but runs great - we helped a friend setup one in a 18 lb model - that was a bit much
your Edge will be a bit nose heavy with that engine.and 16 lbs is a very realistic finished weight.
Old 03-19-2004 | 02:49 PM
Default RE: 3w 50cc
i see...
o.k i am still thinking if i should go with a 50cc gasser or a moki 210.
thank you for your help.
roy
