2 stroke oil ????
Old 04-03-2004 | 04:26 AM
Hisham's Avatar
Default 2 stroke oil ????
Guys,
What type of 2 stroke oil are you using for your Zenoah G62 engine???
Synthetic oils are not good for breakin, right???
A guy recommended the MOTUL pure synthetic oil to be used after the breakin...
thanks
Hisham
Old 04-03-2004 | 06:21 AM
My Feedback: (16)
Default RE: 2 stroke oil ????
I use AMsoil at 80:1
Old 04-03-2004 | 07:34 AM
OSilfa's Avatar
Motul is an exellent choice an for breakink you can use it,just take a little more time for breaking.Use the ratio recomended for the manufacturer.
Oscar Silfa
Old 04-05-2004 | 01:53 AM
Hisham's Avatar
Thanks fo rthe replies...
OSilfa
You think i can safely use the MOTUL fully synthetic
oil for break-in the G62...???
H
Old 04-05-2004 | 08:24 AM
OSilfa's Avatar
Yes,you can use with confidence.
OScar Silfa
Old 04-05-2004 | 09:36 AM
Hisham's Avatar
The manual of this engine, says that
the mixing ratio should be between 25-40:1
a bit confusing???
What is the recommendation in your opinion??
H
Old 04-05-2004 | 09:50 AM
Hisham's Avatar
http://www.modelflight.com.au/rc_mod...zenoah_g62.htm
this site suggests using 32:1 mix ??
is it for breakin or after...??
Old 04-05-2004 | 10:41 AM
OSilfa's Avatar
For Zenoah use 32:1 all time
Oscar Silfa
