Engine stand offs
Old 04-26-2004 | 09:49 PM
rcnats's Avatar
My Feedback: (56)
Default Engine stand offs
I need a set of engine stand offs to mount my Sachs 3.2 with a Pitts style muffler. I have seen them but cannot remember who makes them. Can any body help? Thanks.
*rcnats*
Old 04-26-2004 | 11:02 PM
gunny11's Avatar
Default RE: Engine stand offs
http://www.rcshowcase.com/html/acces...html#standoffs
I get mine from RCshowcase.
Gunny
Old 04-27-2004 | 04:57 AM
Jemo's Avatar
You can get them from Roger (aerografixs )
, right here on RCU. He will make any size you need.
http://www.aerografixs.com
Old 04-27-2004 | 09:50 PM
platero's Avatar
aerografixs is your best choice nice products at
Old 04-28-2004 | 10:46 PM
rcnats's Avatar
My Feedback: (56)
Thanks! It good to get help from fellow r/cers. Now for the hard part...which color?
*rcnats*
Old 04-29-2004 | 06:26 AM
Jemo's Avatar
That's only a hard choice if you have a clear cowl........
Old 05-01-2004 | 07:49 PM
My Feedback: (13)
I make mine from an oak board. Use a drill press to drill the thru hole. I used a piece of oak from my kitchen floor project. The plank is about 1/2 inch thick, so I cut it in to 1/2 inch width using table saw. Now I have a board 1/2 inch square. cut to length. Then drill the thru hole. The hole thru the oak is parallel to the grain of the wood. Works well and you can make various lengths easily. I have 2 or three degrees of right thrust, and the firewall is square. So I make two of the standoffs shorter than the other two. Put the short ones on the right. I even cut the ends at a slight bevel (2 or 3 degrees) so that they meet the firewall squarely and the back of the engine evenly. The longest I have ever needed was about one inch long.
