What engine is this
Old 04-27-2004 | 12:05 PM
Default What engine is this
I bought a plane with this engine in it but don't know what it is. I was told it was a 3w engine
On the cylinder is marked 1D 3+
12110011 927
Does anyone know what make and size this engine is?
Old 04-27-2004 | 02:08 PM
My Feedback: (18)
Default RE: What engine is this
I.I.T.M.I.S.= incificent information to make an intelligent statement
Old 04-27-2004 | 03:51 PM
Antique's Avatar
Most 3W engines don't have numbers like that..Looks like the casting numbers on a Sachs 5.2....Could be an early 3W 60...
Old 04-27-2004 | 05:36 PM
There is also a number stamped on the crank case where the cylinder bolts to the crankcase ( 026)
What is the formula to figure out the displacement of an engine
Old 04-27-2004 | 06:15 PM
Do you have a picture?
Old 04-27-2004 | 08:30 PM
Antique's Avatar
If the carb on the engine is original and is a Walbro it can be cross referenced to the manufacturer...
Old 04-27-2004 | 09:28 PM
I don't have a digital camera so no picture. The carb is a Tillotson made in the USA. The carb is mounted on one side of the engine and the exhaust is on the other and it has a prop hub like the 3w. I don't think it is a converted engine as the crank does not come out the back of the engine.
Old 04-27-2004 | 10:40 PM
Antique's Avatar
All 3W engines have cast cases...Machined cases are conversions, some with the back of the crank cut off flush with the rear bearing and made from chainsaw parts....Or in the case of DA engines, CNC machined to their specs....
Old 04-27-2004 | 11:11 PM
jongurley's Avatar
My Feedback: (29)
I'd sell it....[8D]
