bme 44 spark plug?
Old 05-01-2004 | 12:43 PM
Default bme 44 spark plug?
I bought a used bme 44 and I want to change out the bosch plug thats in it. I have the rubber boot type ignition setup. I can't find the bosch r10 865 anywhere local. Anyone with a bme 44 what plug are you using and where can I get them?
Old 05-02-2004 | 02:44 AM
Antique's Avatar
Default RE: bme 44 spark plug?
www.sparkplugs.com..
r10 865 is not a good Bosch number, look elsewhere on the plug...WSR6F is a Bosch number
Southwest Diesel in Phoenix is a Bosch distributor
If it's a 10mm thread plug there are 3 resistor plugs, Champion, NGK, and Denso...Zenoah G23 and G26 engines use the Champions and NGKs with rubber boots...They work without interference on RC models....The Denso plugs are about 3/8" longers....All three can be ordered from sparkplugs.com....Don't go to Horizon, they charge about double....
I tried to go to sparkplugs.com from the link at the top, I guess Marc doesn't like advertising..
Type it in your browser search engine
Old 05-02-2004 | 09:59 AM
www.sparkplugs.com
there is a couple extra .. that stops the link.
I was looking for this link I need a few plugs also.
Tony
Old 05-02-2004 | 10:01 AM
Antique's Avatar
How come it worked last night from my post, then quit ? And now it works from yours ?
