DA 50 wiring question
Old 05-03-2004 | 01:45 PM
Ragz's Avatar
Default DA 50 wiring question
OK, this is my first ever gas engine so I need some help. Engine came with no wiring diagram. The ign box has 3 wires coming off it.
The one that goes to the spark plug
The one that is behind the prop shaft that goes to a flat connector on the ign box
The one with a unique red and black connector
I reckon the red and black unique connector is a power supply cable. The engine came with another wire in a plastic bag that has a similar connector on one end, and NO connector on the other. My Ques. is: How to connect this wire to the battery and switch? What kind of connector should terminate this wire? I hope my question is clear.
Old 05-03-2004 | 01:54 PM
Antique's Avatar
Default RE: DA 50 wiring question
Connect the red wire to one side of the switch, other end of the switch to the red on the battery...Connect the black to the black on the battery...
