fuel proofing?
Old 07-10-2004 | 01:16 PM
Bass1's Avatar
Default fuel proofing?
Is there a prefered method of fuel proofing "gasser" firewalls? I normally use thinned epoxy. Is there anything better(cheaper)? Thanks in advance
Old 07-10-2004 | 01:24 PM
Big_Bird's Avatar
Default RE: fuel proofing?
On my gassers I never fool with fuel proofing the firewall. No need to. If you want to then a little epoxy or polyester resin will be fine.
Ken
Old 07-11-2004 | 04:59 AM
Jemo's Avatar
The thinned epoxy is fine or a polyurethane spray.
Even though the problem isn't as bad as with glow. Oil is Oil no matter what it's mixed with, so you should fuel proof.
Old 07-11-2004 | 06:46 AM
My Feedback: (16)
Just use the paint that is compatable with plane covering film.
Old 07-11-2004 | 10:26 AM
Panzlflyer's Avatar
My Feedback: (15)
Thinned epoxy or spray paint sprayed into a jar if you have to brush it on
Old 07-11-2004 | 01:20 PM
Bass1's Avatar
Thanks for the info. I think I'll just go with the thinned epoxy.
Old 07-11-2004 | 04:12 PM
My Feedback: (14)
You have to kidding - right? You have $600-$1500 invested in an engine, maybe another $500-$1000 in electronics, another $600-$3000+ in an airframe and you are worrying about the $.30 cost of epoxy to fuelproof the firewall?
Old 07-11-2004 | 04:46 PM
Bass1's Avatar
No, I wasn't kidding. I'm out of Epoxy and my LHS is 40 miles away!
Old 07-11-2004 | 10:00 PM
EJB
Nothing wrong with thinned epoxy EXCEPT that it's alot more ($$$) than a clear POLYURATHANE that you can get at any K MART,WALMART, MENARDS or any hardware store.That's right-it's cheaper & works just as well.
And when your muffler comes loose you will find out why it's a MUST to seal raw wood with the epoxy or polyurathane.
Old 07-11-2004 | 10:50 PM
Bass1's Avatar
I have a Hardware store close by and will check out the Polyurethene
Old 07-13-2004 | 01:39 PM
My Feedback: (14)
Actually I submit that polyurethane if a LOT more expensive a solution than epoxy. We all use epoxy all the time, but a pint (or quart) of polyurethane with a limited shelf life? If you have no other use for it, the polyuerethane will go off long before you use it up. At $7 a pint that's a pretty expensive solution.
Old 07-13-2004 | 02:53 PM
Bass1's Avatar
Well after realizing I needed a few more items to complete the project I made the trip to the Hobby Shop and just bought Epoxy. Now I need a new kit so I can use all this Epoxy
Old 07-14-2004 | 11:07 AM
EJB
ORIGINAL: GeraldRosebery
Well,of course I had to run out & check the prices at Menards.
Minwax "Fast-Drying Polyurethane",1/2 pint(8 fl oz.) $3.75
A quart is $6.04...a good deal if you're also re-finishing a chair or if you're building 300 planes. Spray can(11.5 fl oz.) is $4.75
Other brands are a little higher but still cheaper than the epoxy.
Tower Hobbies Epoxy is $7.99 for 9 fl oz. Cheapest I've seen.
You're right about the limited self life,the urethane in the can will harden up in a few months.
The Polyurethane straight out of the can still get's my vote.
