ignition batterie ??
Old 07-23-2004 | 01:08 AM
wizard026's Avatar
Default ignition batterie ??
Hello guys !
will you consider that a 4.8 volt 1400mah (NiCad) will be enough for a DA50 ignition ? DA recommend a 900 mah or larger but i don't need too large
thanks !
Old 07-23-2004 | 05:54 AM
My Feedback: (20)
Default RE: ignition batterie ??
ORIGINAL: wizard026
Hello guys !
thanks !
That will be perfect!
Old 07-23-2004 | 05:58 AM
My Feedback: (18)
Well let us look at this.
#1 DA recommends a 4.8 volt battery. You have a 4.8 volt battery , #1 CHECK !
#2 DA recommends a 900mah or larger capacity battery, You have 1400 #2 CHECK !
You have met all requirements. Put the battery in, start it up and FLY the thing.
Old 07-23-2004 | 11:25 AM
That's the same battery I have on my DA 50 and it works fine.
Old 07-23-2004 | 12:09 PM
wizard026's Avatar
thanks guys for quick reply !!
