DA50 awesome engine
Old 08-15-2004 | 11:21 PM
Default DA50 awesome engine
Just fired up my new DA50 the other day. What a motor. Started right up, ran great, flew the plane even better. Only had 7 flights so far but the engine is so smooth and easy to tune right. It already idles at 1600 and peaks at 6500. Just gotta figure out a bit of a throttle curve for better hovering/harrier control.
Old 08-16-2004 | 01:27 PM
My Feedback: (14)
Default RE: DA50 awesome engine
If you are flying Futaba, try -70 throttle expo...that's right MINUS 70....huge sweet spot in the midrange...... I know it sound like allot, but that's what is working on my DA~50 Wild Hare Edge
Good luck,
Old 08-17-2004 | 07:29 AM
RickP's Avatar
Good luck with the 50, I had some hiccups with mine, but DA's service has been awsome. First time I humped up the head when my header cracked because I didn't support the pipe right, Da replaced the jug and all rotating components free of charge. Then something happend after 4 gallons later. Some rod noise started. Again all rotating compoents free of charge. Both fixes were in under a week too. Other then that it's an awsome motor - Enjoy!!!
RickP
Old 08-18-2004 | 03:15 PM
I have to agree with you guys. The DA50 is an awesome engine as well as the outstanding service that DA provides. I unfortunately had the mishap of a piston failure a while back. I sent the engine in and within a week it was turned around as good as new. Best of all , they stand behind their product and absorbed the cost of the repairs. I know when I need another gas burner , it will be a DA...
Old 08-19-2004 | 01:18 AM
i have both da50 and 3w50,
but i like da50 better due to its light, easy starting, more power.
Thanks.
Old 08-19-2004 | 06:15 AM
Scoubidou's Avatar
My Feedback: (17)
Is it a problem if i cut the heavy black & red connectors on the ignition? I would like to replace them by a standard RC battery connector like we use for the switch.
Old 08-19-2004 | 09:11 AM
GoeKeli's Avatar
My Feedback: (18)
I love my DA50. It also went to the shop once and was back over night same week I sent it and better than new. I just ordered another yesterday. I would like to own their other engines as well someday. I have over 16 gallons through my engine and it is very very powerful. It is on a GPPW and is going on my 2.3 extra very soon. Thanks RickP for the inspiration!! DAs customer service is second to none!!!
Good luck Touchdown, and have fun!!
Joe
