zdz timing
Old 09-30-2004 | 08:20 PM
My Feedback: (7)
Default zdz timing
i have a zdz 80 rv single. has anyone set there timing. when i got my engine. new. the pick up sensor holder was at the most advanced position it could be. they say its set from factory. i tried to decifer the web sit. and i aslo looked at my book. it says at top dead center its supposed to be 6 mm from the middle of the magnet to the middle of the magnetic pick up. i did this. but it was very very hard to start. has anyone advanced there timing without problems. or how have others done this. i did advance it a little. and it started much better. and ive never herd preignition. the engine is still braking in. ive only had about 2 gallons of fuel thru it. and what rpm are anyone else getting out of these engines. with say a 26 10 prop. mines a 3w prop. im still running it richer. anyhow any help with this timing issue would be great. the translations from zdz to english is a bit confusing.. thanks for any help
Old 10-01-2004 | 12:40 PM
My Feedback: (7)
Default RE: zdz timing
welp guess not
Old 10-01-2004 | 04:25 PM
Do a search for your engine on RCU and you will find lots of info.
Old 10-01-2004 | 07:56 PM
Big_Bird's Avatar
Look at this link and time the 80 as shown.
For what it's worth my ZDZ80RV with a Bisson Pitts style muffler turns a Bambula 26x10 around 6100 depending on the weather. Mine starts very easy.
Ken
http://www.rcshowcase.com/html/faq.html#sensor%20set
Old 10-01-2004 | 10:14 PM
My Feedback: (7)
thanks very much. appreciate it.
