Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Information needed!!3.7 Sachs engine >
Old 10-11-2004 | 08:04 PM
Default Information needed!!3.7 Sachs engine
Okay I want everyones opinion and any relevant information..Props, RPMs etc...It has a spring starter and starts very easy..Have it on Patty Wagstaff 25% but not flown it yet..
Old 10-12-2004 | 04:54 AM
My Feedback: (13)
Default RE: Information needed!!3.7 Sachs engine
I have two of them..one with C&H ignition and the other with a spring starter..Am using a Zinger 22-8/14 wooden props...Both are in my scale planes and they run very good..Be sure to grease the spring statrter at least once a year..other then that, I have no problems with them..Probably best to ask someone in regards to props to use on your stunt plane..Check out the Metz props....I really don't know what size you can use....Good luck...
