Quadra Engine Size
Old 10-18-2004, 09:03 PM
rcglert
rcglert's Avatar
Default Quadra Engine Size
Hello all,
I have an older Quadra engine that I assumed was a 40cc. Well, when I ordered the 40cc piston and ring, it was too small. The case looks almost identical in size to the 35cc. The markings on the case are as follows: RD 502, 20800, PETCO and Made in Canada. This engine has no breaker points.
Any ideas on how big (or small) this engine is?
Thanx,
Tom
Old 10-19-2004, 01:03 AM
Antique
Antique's Avatar
Default RE: Quadra Engine Size
Petco was the "in between" company from Quadra to US Engines...It has to be a 41 or 42, check with Dick Bennett at www.bennettbuilt.com..
Old 03-08-2024, 06:41 PM
bran_den13
Originally Posted by rcglert
Hello all,
Thanx,
Tom
Hey Tom! Just wondering what all you were able to learn about this engine? I have one with the exact same markings that I would like to rebuild. It came on an ice auger that was handed down from my late father in law. Having a hard time finding any info online. Anything you could tell me about it would be greatly appreciated!!
Branden
Old 03-09-2024, 06:28 AM
Tony Hallo
I have a 40 size Quadra sitting on my bench, it is partially disassembled but it did run. Can't find any numbers on the case and it is a point style engine if it would be help to you. Cant tell how long it has been sitting there!
Old 03-12-2024, 07:21 AM
larry@coyotenet
My Feedback: (21)
Probably a Quadra 52, lots of the 40's had new jugs installed to up the cubic inches.
Old 03-12-2024, 02:45 PM
Propworn
Propworn's Avatar
This is the book you might want to get if you are going to play with Quadra engines.
Amazon Amazon
bran_den13 (04-12-2024)
