engine of choice
Old 10-30-2004 | 12:56 AM
Default engine of choice
my h9cap232 73"ws is ready to 3d the sky
can u guys suggest a engine of choice for glow and gas
Old 10-30-2004 | 01:35 AM
Default RE: engine of choice
well, guys are putting 50cc gassers in 80 inch planes,,, so I will tell you MVVS 35cc, gass or glow.
Jim
Old 10-30-2004 | 11:02 AM
Don't go with a gasser in this plane, it just comes out too heavy to benefit. It will fly well with an OS 1.08 two stroke and up, and better still with a Saito 1.80 four stroke. Moki and YS both have engines in similar sizes that would be excellent choices, and keep the flying weight down. With your plane, as in most others, lighter flys much better.
Old 10-30-2004 | 12:11 PM
how about os160fx which needs a home and is only couple oz heavier
than saito180/moki/ys
apart fr vibration rcs1.4 is also light and powerful
i got to try out gas engine in my rc life
Old 10-30-2004 | 01:15 PM
If you want to go gas, start with a plane in the 80-85" span range, powered by a 50cc gasser. That's the bottom end of the gas engine range that makes sense for aerobatics. The small ones have too high a wing loading and are down on power.
Old 10-30-2004 | 02:30 PM
The os 1.6 would be fine. It's still a little on the heavy side, but to nowhere near the extent a gas engine would be.
Old 10-30-2004 | 03:02 PM
Cap232tain's Avatar
Sorry, I'll have to disagree with Diablo! But it depends on your description of unlimited! This 1/4 scale tipped the scale at 12lbs. 2oz.!
ID:	188177   Click image for larger version
