BME 50 CARB #
Old 11-25-2004 | 09:46 AM
Default BME 50 CARB #
Can someone tell me what the walbro carb # is on a bme 50?
Old 12-02-2004 | 12:42 PM
Default RE: BME 50 CARB #
Does anyone know.
Old 12-02-2004 | 01:00 PM
Antique's Avatar
Keith at BME does
Old 12-04-2004 | 10:04 AM
Do you know keiths email address? I would like to ask him.
smallplanes
Old 12-04-2004 | 11:04 AM
Antique's Avatar
[email protected]
The carb is most likely a WT76A
Carb diaphragm kit is D10 WAT, list price is $3.94
Complete Repair kit is K20 WAT, list $7.23
A complete carb is $50.56
Old 12-04-2004 | 05:00 PM
Thanks for the info i will email him. Let me know on those ignitions.
Smallplanes
Old 12-06-2004 | 03:20 PM
My Feedback: (37)
My BME 50 has a WT250 on it.
Tim
Or at least that's what is says on it.
Old 12-06-2004 | 03:46 PM
Antique's Avatar
List price $48.20
Original application Tanaka SP 380 chainsaw..
Old 12-06-2004 | 04:11 PM
My Feedback: (37)
Why would they do that? Aren't these engine right from Echo? Another question that I have is why would it use a WT style that is for 30-50cc when my BME 44 has an HDA62. The HDA style cover a broad cc range, from 30 -60cc if not mistaken. I am not knocking either BME or their engines, I love both. The 50 is stronger for sure, mostly from the larger transfer ports I believe.
Ralph..what was the HDA62 O.E.M. use.
Old 12-06-2004 | 05:36 PM
Well witch is it the WT250 or the HDA 62? The whole truth to the matter is that i want to see if its the same carb as on a poulan 46cc chainsaw. My thinking was if i had a little bigger carb than stock i could get more power out of it. I have not installed it on anything yet but i want to make sure it will have plinty of pep. Thanks guys and tell me what you think.
smallplanes
Old 12-06-2004 | 06:19 PM
My Feedback: (37)
BME 50 = WT 250
BME 44 = HDA 62
Old 12-06-2004 | 06:24 PM
Ok thanks i'm going to check mine if its not that one i might get the wt250.Thanks
Old 12-06-2004 | 09:11 PM
Antique's Avatar
Keith is no dummy, he puts the carb on his engines that work the best...A larger carb will not make it run any better..If it did he would put it on there...
The HDA62 came from a Zenoah Red Max G4K hedge trimmer...
WT 250 11.1mm bore
HDA 62 12.7 mm bore
the WT 76A I thought might be on there has a 13.49 mm bore, used on almost all 3.2 size engines..
A larger carb making more power is mostly wishful thinking...A G62 has a 15.08 mm carb on it...I put a SDC80, 19.05 carb on one...NO DIFFERENCE at all......
Go with what the manfacturer set it up with, he knows more about his engine than we do.
A G26 runs the same, within 100 rpm, with a 3/8 carb as it dies with a 1/2 inch carb..Been there.....[8D]
Old 12-06-2004 | 09:22 PM
The carb on my poulan 46cc motor is WT 657 . What carb do you think i need? Do you think the one on it will do just as good as what the BME has on it. I email that guy Keith but did not get a reply. Let me know RCIGN 1
smallplanes[sm=confused.gif]
Old 12-07-2004 | 05:56 PM
Ok Keith at BME says that the BME 50 has a WT-201 carb on it. Thanks Keith your a good guy.
smallplanes
Old 12-07-2004 | 06:16 PM
Antique's Avatar
13.4 mm, Echo 4000 chainsaw, list $54.32....
