Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
CA Models 31% Extra 300L - What Engine? >
Old 09-02-2002 | 04:06 AM
Default CA Models 31% Extra 300L - What Engine?
I'm trying to decide what engine to put on my new CA Models 31% Extra 300L, there specs call for a finished weight of 17 to 20 pounds, has a 93" span and calls for a 45 to 80 cc engine. I'm looking at the ZDZ 60 and ZDZ 80, seems the 80 might be a bit much for that weight. Would the ZDZ 60 give me unlimited vertical? Any other engines I should look at in this size?
Mark
Old 09-04-2002 | 04:19 AM
Mark,I would go with the 80.The plane you are getting is almost the same size as a hanger 9 cap with a 97 inch span.Most people are using the zdz 80 and it is a power house.You won't go wrong with the 80.You will have unlimited vertical.I had a extra with a zdz 60.(80 inch wing span)This plane weighed 15 lbs and was a rocket.Have fun, you will enjoy flying it.I have a hanger 9 cap with the 97 inch span with a zdz 120 twin for power.Latter
