DA-50 Factory Needle Settings
Old 02-12-2005, 07:34 PM
Default DA-50 Factory Needle Settings
Does anyone know the factory Hi and Lo needle valve settings for the DA-50?
Mike
Old 02-12-2005, 08:00 PM
My Feedback: (18)
GoeKeli's Avatar
Default RE: DA-50 Factory Needle Settings
Hi Mike,
the instructions say to start at 1.5 turns out on both high and low.
HTH
joe
Old 02-12-2005, 08:27 PM
min
Go with 1 3/8 on low, 1 3/4 on high for starting a new one.
Good luck
Old 02-12-2005, 11:09 PM
Antique's Avatar
Factory settings are just an educated guess...They ASSume the customer will know how to set the carb, so they go a little rich to keep the engine from sticking if said customer doesn't adjust the needles to suit the prop size and altitude...If you start 2 turns open and set the high for max rpm, then set the low, your engine will be closer to being right than if you just go to 1 1/2 on both and leave it there...
ASSuming again....
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
