Highest Performance G-62
My Feedback: (19)
VA
What is the highest performance figure (rpm/prop) you've seen for a G-62.......I talked with a guy one tie ....who said he had one turning 9000...
What can you do to one to get a h.p. boost ??
Different Carb ? Heavier Breathing Exhaust ?? porting ??
It would make sense that if you can get more fuel in// and more exhaust out// you should see a rpm increase ??
Id like to have a 22/10 turn 8500/9000
What have you seen or heard ??
Normal rpm for a G62 is around 7000 with a 22-10 Zinger and no muffler....I once turned one 12,500..With a 15-10 prop...Switching to glow would give you more rpm and about 1 lb less weight...There was one advertised somewhere on here with a tuned can muffler, stock on gas, turning lots more rpm....
