G 26 carb fitting?
I have a new G 26 and would like to replace the nylon gas line fitting on the carb. I have the new metal part already. Before I end up "butchering" the carb....... how do I remove the old nylon, elbow, carb fitting?
I am afraid I will break off the end, in the carb, or leave a chunk of nylon in there that won't come out. ...... thanks in advance.........lownslo
It's a presss fit in the carb..The center is brass..It will plastic break off when you try to remove it, leaving the brass in the carb..Grab the brass with a small Vise grip and twist and pull it out...If you can't get it out that way get a 4-40 tap and screw it into the hole..When the tap bottoms out in the hole it will push the brass out....Use a litte care, the tap could break off...I remove the fittings all the time, have not broken a tap because they mostly come out with the Vise grip...
That's a good question Marty. The answers are .... yes and yes. Actually it sounds like I could cause more problems getting it out
....... soooooo..... I think it will be a spare part. (just in case). Orientation problem is not critical enough to chance possible problems either. ... lownslo
My Feedback: (42)
TX
ORIGINAL: lownslo
(I may need to make this change on my MVVS 215 to resolve a throttle linkage problem)
Marty, This is the part I purchased from my LHS...ordered through Horizon.
http://www.horizonhobby.com/Search/D...&OverallCatID=
I am not sure if you will gain any clearance as the part is the same configuration, I think. I needed to rotate mine a little. I figured if I had to break it loose, I might as well put in a metal one.
lownslo.
lownslo.
