Charging ignition battery
Old 03-14-2005 | 04:55 PM
Josey Wales's Avatar
My Feedback: (61)
Default Charging ignition battery
Do you guys using a DA ignitions disconnect the pack and charge direct or do you use a separate charge jack (ernst)..Just wondering cause it says in the DA manual to isolate the pack from the ignition
Old 03-14-2005 | 09:03 PM
Nogyro's Avatar
My Feedback: (10)
Default RE: Charging ignition battery
I just use the charge jack that comes off the switch. Been working fine all summer and packs cycle out at max....
Old 03-15-2005 | 10:05 AM
My Feedback: (16)
While I don't have a DA the MPI or JR switches both have built in jacks that make the charging of ignition batteries easy.
