Walbro choke
IN
Walbro choke
Anyone know for sure if a Walbro carb will meter fuel if you remove the choke shaft and butterfly? I removed the choke on mine (for cowl clearance) and it won't run right above half throttle. I'm thinking that it's possible that the choke shaft provides more vacuum on the high speed needle port in the carb. Acts like the high speed circuit won't flow fuel. I've gone through the carb and put a rebuild kit in it. Still runs the same. It's a new engine that I didn't run before I removed the choke, so I can't compare the before and after. Pulse port is clear, gaskets sealed.
IN
RE: Walbro choke
Yes, they are pumped. But they won't flow any fuel unless vacuum pulls fuel out of the orifices, which then pulls on the metering diaphragm which then opens the needle off the seat.
My Feedback: (16)
GA
RE: Walbro choke
Removing the choke will not make a difference.
With that said, if you adjusted your engine but the choke never opened up all the way, then removing the choke butterfly will make a big difference.
ORIGINAL: Diablo-RCU
RE: Walbro choke
Removing the choke in general improoves matters, because the airflow in our model planes pretty much upsets things, mainly WOT response. My favourite Walbro has no choke
It is the venturi that provides the fuel draw by Bernoulli's law. Not the choke, which only aids in getting a very rich starting mixture. After that, the prop blast against the open choke plate only creates problems.
My Feedback: (16)
GA
RE: Walbro choke
What you say is true, but if the choke is partically closed, it will cause more fuel to draw when the engine is running.
If you don't believe me, try it. I did once by mistake. To get it to run, I had to lean the carb. When I found the problem and corrected it, (servo didn't allow choke to open all the way) the engine was too lean and I had to richen it up.
ORIGINAL: preivers
My Feedback: (40)
NH
RE: Walbro choke
So with the choke removed, how do you start it? With no cowl, you could stick your thumb down its throat, but with a cowl, what's the starting routine? Gasser newbies want to know!
RE: Walbro choke
Yep,
You also don't run cars with the choke partially drawn. Thank G*d the device now is automatic and needs no consumer input, or integrated in the fuel injection cirquittry.
I myself prefer turbo charged diesel engines: get the go without the woe.
RE: Walbro choke
As far as I know, there are two methods to choke without a choke.
1) construct a device that will push on the regulating membrane. This will allow the pump to inject fuel directly into the carb, even without choke. Just bumping the prop to and fro against compression will get the engine wet and hissing. I have successfully used some spring wire with a branch soldered onto it. In the steel cover I drilled a central hole to provide access to the diaphragm plate. The steel wire was secured under one of the cover corner screws. The push lever can be moved to a convenient location.
2) Add a fuel injection nipple to the crankcase, and use a syringe to inject 0.5cc of fuel directly into the cranckase. This works better than a choke, because now you know how much gas you spent that engine. This also works best in inverted applications, when most choked fuel just drips out of the carb again. (depending on carb position)
IN
RE: Walbro choke
Three more methods:
Squirt WD-40 into the carb.
Stick your thumb in the venturi while cranking the prop with other hand.
Blow into the tube connected to the diaphragm cover vent while rocking the prop back and forth.
This is a side carb engine with easy access to carb.
My Feedback: (16)
GA
RE: Walbro choke
That is an awesome tip.
What is the material made out of and did you have to drill and tap that hole to retain the choke plate?
ORIGINAL: platero
Here is my easy setup for walbro choke, it works fine and no holes in the cowl
RE: Walbro choke
the material is a square of aluminium almost the zize of the carburetor, drill with a drill bite, no gasquet was be necessary, the plastic is high impact, in first try it was aluminiun but not wrok well, this system has more than two years working ok...good luck
RE: Walbro choke
That picture is exactly the same as the ryoby choke.
Yes I know, but the question was. " what to do when the carb is not accessable?"
It just occurred to me that Diablo's solution is probably best:
solder (sodder for northerners? Us furreners find it hard through your dialects) a tube to the diaphragm vent hole, and connect a blow hose to it. For choking, rock the prop whilst "blowing the horn" Then tuck away that Gabriel thing into a no-harm location, and go ahead and start the engine. The lack of mechanical devices will keep that membrane better.
RE: Walbro choke
That is virtually identical to the choke assembly that comes on the Fuji BT-50SA.
After this picture was taken I changed my mind and mouted a Hitec HS-81 on the side of the engine mounting box and direct-connected the choke to the servo. My channel 6 VR switch controls the choke.
RE: Walbro choke
Nice fabrication.
As you can see, however, a walboro carburetor is not different in basic design here. Your same configuration could have been duplicated without the plate. All you need is a spacer and very thin, bendable (spring-like), washer and use one of the mounting bolts.
