BME aircraft vs. BME Engines Props
Old 04-30-2005 | 10:24 PM
Default BME aircraft vs. BME Engines Props
What is the difference between these two props?
I ordered from BME Aircraft thinking that I would be getting the BME prop that has "Engine" on it with the red and white tips, but received a prop that looks similar in shape, and marked with BME Aircraft.
It also looks to be laminated rather than a solid piece. Is this correct, I am thinking laminated is several layers together and then shaped?
Is either better?
Old 04-30-2005 | 10:31 PM
toddblose's Avatar
My Feedback: (10)
Default RE: BME aircraft vs. BME Engines Props
They are the same props, BME aircraft has the Laminated version
