How much is enough ??
In trying to tune gas engines for general sport flying, I have been trying to find anywhere a definite instruction rather than the old 'back off a couple of 100 rpm's', as to how much should the top end be reduced from it's max rpm before flying to guard against lean running.
I have heard some folks say, reduce by 100 rpm, others say 2 or 300, and another faction advocates to richen the high speed needle a 1/4 turn.
Anybody willing to take the plunge to be more specific on this, or is the variance of such that one can't be specific as each make and size of engine requires a different setting.
My Feedback: (10)
ORIGINAL: karolh
karolh, I think it is simply not that critical. If you are to the point that you need every last rpm that an engine will turn then you may need a larger engine.
I richen my engines by about 200 rpm from peak which is usually about 1/8 turn and have never had a problem with lean runs. The spark plug also runs a nice tan color.
I don't think you will find any information more precise than this, only different opinions.
Ken
Ken
You say "gas" engines. Do you mean gasoline or glow fuel? For a gasoline engine, they can be run at a full lean setting. In fact, once set, they seldom need adjusting. Glow fuel engines are another breed. Set the needle for a full lean setting on the ground. Briefly pinch the supply fuel line. If the engine starts to die immediately, it's too lean. If it runs a while, then dies, it's too rich. If it speeds up a little, then dies, it's about right. Fly the plane. Pull a tight loop. If the engine sags at the top, it's still too lean. If you see a lot of exhaust residue, it's too rich.
Dr.1
Dr.1
