BME help
Old 06-22-2005 | 02:41 PM
Default BME help
Hi Guys I just found a problem with my ignition and ordered a new one. While running my engine I noticed a burbale every time I turned a few guys at the field adjusted my needles and things got better but then wile fying I put my plane into a spin and when I went to raise my throttle the engine hesitateed like it was going to stall to the point where I had to play with the throttle to keep it going and then it ran fine again I laned and one of the guys told be that I may be a bit rich on my lowend I leaned up my lowend it seemed fine on the ground and then when I put the plane into a spin the same thing. I then laned the plane and on taxi it stalled try to strat it again it started then stalled started again and it backfired and then I could not start engine anymore when I got home I found the problem was ignition. So I now have my ignition comming in and would like to no how I may sove my spin problem.
Rob
Old 06-22-2005 | 03:16 PM
My Feedback: (16)
Default RE: BME help
Make sure that the engine doesn't hesitate from idle to midrange or WOT.
If it hesitates then you need to richen the low end.
Old 06-22-2005 | 10:41 PM
RTK's Avatar
RTK
Do you have the hole on the diaphragm side shielded or run into the fuse?
