Gas Engine Newbie
Old 10-22-2002 | 05:35 PM
M3
My Feedback: (25)
Default Gas Engine Newbie
OK, I have the Wagstaff 300 and am now considering a gas engine (BME 50).
I have absolutely no experience with gassers and have some questions:
1. Do I need any special starting equipment?
2. What gasoline do I use (literally, BP, Shell, am I nuts, etc?)
3. Do I need a special gas tank?
4. Does the gas engine need a "glo" warmer per se?
Thanks for responses and sorry for the really basic questions. I am trying to decide what type of engine would be best for me (and the plane), i.e. two stroke, four stroke or gas.
Old 10-22-2002 | 10:43 PM
Default Newbie.
Use any 87 - 89 octaine gasoline but mix at least 32 to 1 with a quality two stroke oil.
I use Dubro glo tanks but you must use a fuel line made for gasoline. It's available at your local hobby shop. You must also use a tank plug made for gasoline for your vent and supply lines.
You will not need a glo warmer as gasoline engines use a spark plug, not a glo plug.
As for starting equipment, some flip them by hand but I use a Sullivan Dytronics starter with a Miller reduction unit. Saves fingers and keeps the old arm from getting sore.
Suggest you have a fire extinguisher handy also, never know.....
