ZDZ 160B2 Champion on pipes
Anyone out there with a ZDZ 160B2 Champion on the large KS tuned pipes ie the 1090s. I'd like to know how the motor responds over the full range on tuned pipes as opposed to cans/mufflers please, cheers
RE: ZDZ 160B2 Champion on pipes
Works well - on 30x10- 32x11 prop - is extremely quiet in air - very smooth quick throttle up at low rpm etc..
Good prop selection for IMAC 3D seems to be in the 6000-6300 rpm band
Thank you, what sort of gain in power do the pipes achieve over the cans say JMB for example, ball park idea, like is it worth the extra effort!
cheers
cheers
About 300 400rpm typically on same 30x10 prop .
Is it worth it ?
the really short header and the big JMB cans are really easy to do and sound very mellow and quiet.
Also a lot cheaper!
The power difference is definately noticable .
We have setup the ZDZ160's in 35% "heavy" models using in cowl mufflers .
This is a great setup for planes which really don't perform on 100"size" engines
Around 35 lbs the JMBS are still a good choice - After that - if you are at 40 lbs - the pipes are the way to go.
Unlimited stuff and 3D all are fine -even here at high elevation.
Is it worth it ?
Also a lot cheaper!
Excellent, sounds like you have been where I would like to be! Is the header length reccomended by KS ideal with the 1090s
cheers
cheers
UT
ORIGINAL: Camel
I thought Brian's were 1090's ---
I guess the 1090's were the ones I put on York's plane
I now have also -some big AMT's which really work -a bit heavier but really tune well.
I have only used one so far -on a 80 single and it worked extremely well with 80CM from export to ring on pipe - that's a header of about 12"
I was turning in 7000+range so -more length may be required-
The 160 likes running right around 6000 (as will the 80) so I will have to see what transpires on next setup - It is going into a 40% Extra-
One thing for sure-- small diameter headers are not as efficient . I am using only 30mm now
Not a big difference but noticeable.
Right , so what I'm hearing is that I can save space money and 8ozs for the same performance then, by using the 1080s?
UT
ORIGINAL: Camel
