Running Temp for 3W 60cc
What should the normal running temperature of a 3W 60cc be. I have one in a cowled YA P47 and I am just running in the engine. I have cut some vents for cooling but need to check if it is effective. I suppose it is in the range of 140c to 180c. right?
My Feedback: (36)
ID
RE: Running Temp for 3W 60cc
You want it between 160-220 F any hotter than that is not good. Can't tell you what that is in Celsius!!! And make sure you have a good exit for the air, at least twice as big as the inlet if possible.
Tom
Tom
